Hi everybody,
I am completely new to the MPCNC and this forum.
I have a finished working build and already did some nice cuts with it.
My problem is that it the cuts are not square ( was not important for the cuts I made so far )
So I checked the rails, and they are more or less square.
( I actually find it very hard to measure if it’s square, once the build is complete, any tips ? )
I have my end stops set at exactly the same distance from each corner.
The problem is, when I home the X and Y axes, on both axes, only one of the end stops gets triggered ?? So the gantry is obviously not square.
This brings up two questions for me:
I tried tightening and loosening all the different bolts that should help to square everything, and yes, it makes a slight difference, but not enough. I mean, when I home the axes, one end stop gets triggered but the other one would need like 10mm more travel for it to be triggered. Could my printed parts be bad ? Any ideas ?
I thought that the end stops would kind of “autosquare” everything by running each stepper ( X1 and X2 ) until both hit the end stop. But to me it seems that they both just stop when one of the end stops gets triggered !? So, I dont’t see how this could help with squaring ? I’ve read that maybe the end stops are swapped, so I tried to swap them, but same result. Also, I don’t understand how the board ( using Rambo 1.4a ) could even control only one stepper motor. When I look at the wiring diagram of the two steppers on one axes, I don’t think the board can control only one motor, right ?
( yes, I checked the end stops using the M119 command, they trigger correctly )
Also, in some posts I’ve read that it is important to wire the steppers correctly, meaning it seems important which stepper is X1 and which one is X2. If that is so ( even though I did not see this in the documentation ), how to tell which one is which ?
I also wonder if my steppers are even all running ? I mean, how could I even tell if X1 is running, but X2 isn’t ? ( it would still move the gantry, right ? )
I hope that a was clear enough, because english is not my first language, and all these technical terms are rather new to me.
Cheers,
Jacques
