Hello,
The machine is ready, Dual Endstop the test was the crown.
First I Home X & Y, then printed, when finished I home X & Y and print again to check if it is drawing in the same position.
By the picture it is not.
What I am missing?
Hello,
What I am missing?
Ryan’s gcode has a G92 in it. Did you move the machine after home either time?
Hi Jeffeb3, I home before each draw. but I did not turn off the machine.
If you did:
Home
Some jogging
Start gcode
It would be different if the jogging was different for the two tries. Even if you leave your machine on.
Change the G92 line to G28 X Y, then you will need to figure out the Z as well…My Crown is not a test of the Dual endstops without a lot of work.
