I am virtually clueless with this stuff but i have managed to configure my skr 1.3 with drv8825’s using vscode/platform.io and Anttix’s dual endstop version from this thread. I had to install something else also for it to work but I don’t recall what it was.
I am still assembling my mpcnc so i haven’t been able to verify i have the steps correct and such, but i have connected the steppers and and have verified that they all moved as they should from the display. I did not have the end stops connected.
Since then i have read that this row of red jumpers are for sensorless homing and should be removed for end stop switches. Hoping to get to that point next weekend and with a little luck, all will be well. I’ve been working on putting together a garage PC from an old tower to use with the mpcnc also.
I manage to do the update and still getting this error can someone run the TT code and try help me out , I am almost to my last efforts , I could have manually change all the thing he did in the new marlin 2.0 download which compiles with no issues for me only if i knew what changes needs to be done .heeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeelp
#include errors detected. Please update your includePath. Squiggles are disabled for this translation unit (C:\Users\Mary\Desktop\marlin 2.0 - mpcnc lowrider2 - skr v1.3 tmc5160\Marlin\src\core\serial.cpp).
I ended up setting up the base Marlin 2.0 for the LowRider. It works and now I just need to tweak a few things.
There shouldn’t be a need to update the TT firmware for the board unless you change the board.h file to the newer version. As long as what is in the configuration.h matches what’s in the corresponding boards.h file it shouldn’t make a difference.
I do not mean to be a drag but I will PM you my emaill address to see if you can send me a working file - then I can go in and at least start doing some changes too and it will be a great help at this point for me . I will really appreciate it , if that’s ok with you please and thank you .
In my experience, for every post, there are 10x people watching silently, or will find this in the future. Posting questions, answers, and files in public really helps those people out (I am that person 9/10 times )
I’ll share the file openly with anyone. I just want to make sure it works before I do. I don’t want to put out code that causes someone’s LR2 to crash and burn. Then I’d feel bad because that person would be upset with me. I’m going to work on it when I’m back home later this week so it won’t be long.
So…it’s getting old. Trying to cut a 200x200mm square. Set my steps/mm to 200 and get a 400x400 square. Set to 100 and get a 100x100 square. Calculator says 1/32 microstep with a 16 tooth pulley should be 200. I just want this to work so I can start earning a little bit of money to pay for it. Jobs sitting for a while now.
Great…got it to cut the right dimensions…now when I try to home X, one of my Z motors grinds. Didn’t do it a single time before. As much as I like the idea of having a 48x48in cutting area, I’m beginning to wonder if starting with the LR2 was too much.
Or is it just that complicated board that is giving you all the issues? I know it is frustrating but let us help out could be one of many simple things you simply overlooked. You definitely dove in the deep end by not using recommended stuff but we will get you there.
My next step is to swap the RAMPS board from my 3D printer. I’ll download the original firmware again and see if it works. That’ll be later this week as work is ramping up for the next few days.
What speeds and rapids are you using? If you show us your settings we can try to help, just telling us it isn’t working makes us just guess at issues and that is frustrating for everyone.
You have a board in there that is moving, chances are really good you just have bad CAM. The milling basics and estlcam basics has the right numbers to be using.
Cutting/movement at 1000mm/min, plunge at 300mm/min. ESTLCAM is set up per the guide. However, I don’t think it’s the CAM. I ran a 200x200mm square that didn’t cut through only because I forgot to level the z axis. When I leveled and tried to run again, I got the grind…which now that I think of it, I didn’t disengage the motors when I lowered the one side. I wonder if that had something to do with it.
Further checking shows I have ESTLCAM set to mm/min, not mm/sec. Would that make a huge difference?
There are two settings, one has to be mm/min, the other I suggest mm/s as not many people can judge 300-1000 anythings per minute but, 10mm in a second is pretty easy to visualize fairly accurately.
After taking a deep breath, I went down and checked a few things. First, I found a lot of small chips in both my Y1 and Z1 gears/nuts. Cleaned that out, and things went better. Ran the cut a couple of times and ran into simple issues each time. Router cord got caught on the wheel, piece of wood got bumped between my hard stop and the wheel. I was dumb and put my ruler next to the wheel. Fixing those and hooking up my vac (finally figured out to take the wand out of the hose) helped a lot. Just a couple of more mechanical issues to fix (with the bit length I was using, the 611 plate was hitting the wheel brackets at table level causing my X to not go far enough left for the pass. That will be taken care of when my spoil board is in place).
So, it would seem that a lot of my problems are mechanical user error.
On the estlcam basics page, 5th picture, highlighted in yellow. Very very important.
Awesome! Well not awesome but easily fixed. Some people even have a pre cut checklist to run through before cutting. There are a ton of little things to do but the excitement of cutting something new lets them get overlooked pretty often.
