Steel milling?
Can the machine handle steel milling? It uses belt drive, so I’m a bit worried about stepper slippage due to vibration.
I think that might be a little beyond this machine. Maybe if its just once, but if you plan on doing steel a lot, your going to need a big machine, and a lot of coolant. Vibration isn’t the issue.
Thank you for your reply.
