[Steel Tube] International Edition
This tube is ok for the IE?
http://articulo.mercadolibre.com.ar/MLA-624092987-tubo-acero-inoxidable-aisi-304-254-x-15-mm-x-1-metro-_JM
No, the 25.4mm will not work yet. I will release a version for that soon.
Sorry
Thanks for you answer, i’m thinking that i can sand the end a little to coincide, you think it might work?
Sorry for my english!
Nope, won’t work.
156$ for 1m of pipe!?
For reference I paid, with VAT ~65EUR ~75USD in Portugal, for:
4m of 25x1,5mm SS pipe and
3m of 25mm SS rod.
All AISI 304L
This project shows how this world would be easier with standard measures. Sure the author has a lot of extra work, even with parametric modeling software, that could be used for innovation!
Hi, 156($AR) is like 11$US, after 2 weeks looking for 25mm pipe, I couldt find it, Only 25,4mm one. I find this http://articulo.mercadolibre.com.ar/MLA-616836975-cano-tubo-vantec-fusion-ips-t-sigas-25-mm-_JM
It is steel coated with Medium-density polyethylene (MDPE). Do you think I can use it instead? I would like to know how long will you take to release the 25mm version.
Thanks!
25mm version is out already on thingiverse.
Here is the 25.4mm version, I will be putting it on thingiverse in day or two. https://www.v1engineering.com/forum/topic/25-4mm-beta-set-with-the-new-roller-beta/
I don’t think the MDPE coating will hold up. You need steel.
i didnt see it, thank you!
