Anyone have a link to an 1.9 version of marlin that is dual endstop archim I could try and see if it’s the software. I’d hate to be wasting your time if the endstop shorting has something to do with it.
I think this is good news. Does Z also go very fast?
I think this should set them to 32nd microstepping:
M350 S32
That won’t be persistent. You need to also send M500 to save it.
M502 is supposed to read the default settings from the firmware. It doesn’t save it either.
So, try this:
- Send M350 S32.
- Send M350 again to show me what it says.
- Try jogging 0.1mm on all axis.
- If that works, send M500 to save.
Yes, Z also moves fast.
Send: M350 S32
Recv: Error:Microsteps unavailable
Changing monitoring state from “Operational” to “Error: Microsteps unavailable”
Send: M112
Send: N2 M11235
Send: N3 M104 T0 S034
Changing monitoring state from “Error: Microsteps unavailable” to “Offline (Error: Microsteps unavailable)”
Connection closed, closing down monitor
Weird. What about M350 S16?
Or maybe M351? That looks much more annoying to use.
Send: M350 S16
Recv: MS1|2|3 Pins X:110 Y:110 Z:110 E0:110 E1:110
Interesting.
Your steps/mm will be wrong, but that should work. Have you tested a movement?
I’ll do that now.
I think the last bit might be able to be set with:
M351 S3 X1 Y1 Z1 E1 B1
The code for M351 (as future reference for me or anyone curious):
If you cant set the last bit, or you just don’t want to, the steps/mm should be 100,100,400:
M350 S16
M92 X100 Y100 Z400
M500
The steppers are working properly now. Awesome, thank you! I figured I hosed it with the endstops.
Send: M351 S3 X1 Y1 Z1 E1 B1
Recv: MS1|2|3 Pins X:111 Y:111 Z:111 E0:111 E1:111
Send: M350 S16
Odd, they are all set.
So maybe the pins are not following the naming convention? Shoot, the Archim’s are great boards but they need to stop breaking them in the firmware. Way too much time poking around on them.
…also wondering if the current is the same on the rest of the drivers or if they are defaulted.
Is there a gcode for driver current? I twisted the steppers by hand and the X and Y were pretty hard to turn. Pretty much like it was last time it was working.
Can you share the output of M503?
The command to set current is either M906 or M907, I think. I can’t remember which one is for the archims.
I agree with Ryan that it is strange the microsteps weren’t set right. I don’t know if anyone has tried that before though.
I wonder if this is a problem with the eeprom reset stuff we were working on with anttix. This board did have an earlier version of the code one it. So it is possible for the spot in the eeprom for microstepping to move.
But then, why did M502 not work?
@bugilt, I would understand if you want to just move on. But I would be interested to know what the setting is after an M502:
- M502
- M350
- reset, so it doesn’t save the changes.
No, I’ll do whatever you need to get some answers.
Send: M502
Recv: echo:Hardcoded Default Settings Loaded
Send: M350
Send: M503
Recv: echo: G21 ; Units in mm (mm)
Recv: echo: M149 C ; Units in Celsius
Recv:
Recv: echo:; Steps per unit:
Recv: echo: M92 X100.00 Y100.00 Z400.00 E200.00
Recv: echo:; Maximum feedrates (units/s):
Recv: echo: M203 X50.00 Y50.00 Z15.00 E25.00
Recv: echo:; Maximum Acceleration (units/s2):
Recv: echo: M201 X180.00 Y180.00 Z80.00 E180.00
Recv: echo:; Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
Recv: echo: M204 P180.00 R3000.00 T180.00
Recv: echo:; Advanced: B<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> X<max_x_jerk> Y<max_y_jerk> Z<max_z_jerk> E<max_e_jerk>
Recv: echo: M205 B20000.00 S0.00 T0.00 X3.50 Y3.50 Z0.30 E5.00
Recv: echo:; Home offset:
Recv: echo: M206 X0.00 Y0.00 Z0.00
Recv: echo:; Endstop adjustment:
Recv: echo: M666 X0.00
Recv: Y0.00
Recv: echo:; Stepper motor currents:
Recv: echo: M907 X1125 Z1125 E1125
There’s your current setting. I think that is a bit high. Watch out for the steppers getting too hot.
Maybe this isn’t getting set with M502?
I’ll keep my fingers on those steppers. Anything else you want me to try?
