I found the pins_RAMBO.h and 45 seems to be set, but not being controlled when i export the gcode in lightburn
// M3/M4/M5 - Spindle/Laser Control
// #define SPINDLE_LASER_PWM_PIN 45 // MUST BE HARDWARE PWM #define SPINDLE_LASER_ENA_PIN 31 // Pin should have a pullup! #define SPINDLE_DIR_PIN 32
I have the pins used for every board I have tried listed on the boards page. I thought they were linked form the laser page as well? For 12V you use a fan port, for 5V you use a signal pin specifically the one I have listed for your board, each is different. There are also other pins you can use but most only need one free pin.
Uninstall the Windows Store version of Arduino and install the normal Desktop version. The WS version isn’t terribly robust. (And for heaven’s sake, attach a text file to your message instead of dumping forty-eleven pages into the message body. :))
Multiple libraries were found for “SPI.h”
Used: C:\Program
Multiple libraries were found for “U8glib.h”
Used: C:\Users\User\Documents\Arduino\libraries\U8glib
Not used: C:\Users\User\AppData\Local\Arduino15\packages\rambo\hardware\avr\1.0.1\libraries\U8glib
exit status 1
Error compiling for board RAMBo.
You need to wipe out all of the arduino stuff and start over. Follow the flashing instructions on this site. The U8glib libraries is messing it up.
