I saw that the store is sold out for the 6A Rambo board with dual firmware and wire set. When will you get these back in?
I’m going to be routering 4 - 6 ft 4x4 with intricate carvings, do I need the dual firmware and end stops? It seems like they would be the preferred choice for accuracy but, they seem a bit complicated too. How much difference is it going to make? Which bundle do you suggest?
No. On the bundle page I explain what I believe is the best option. Rambo series, if you think you are going to need insane accuracy for some reason add a individual wire kit and use it at a later date. You have plenty to learn before adding all the complexities to your CAM with Dual.
