Hi Guys, while waiting for my spindle to be delivered, I attached a MK8 extruder/hotend to my MPCNC Primo. I added a inductive sensor to the tip of the z-axis as a probe. auto squaring works quite good, but i ran into a problem with auto bed leveling. when i send the G29 command to start the automated bed leveling the x-axis moves proper into the positiv direction, but moves way to less or even not into the negative direction.
has any one an idea, why it is acting like that?
I am using the dual endstop setup with a 6th/external stepper driver on a ramps1.4 board.
my modifications in Configuration.h : #define TEMP_SENSOR_0 1 #define X_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. #define Z_MIN_PROBE_ENDSTOP_INVERTING false // Set to true to invert the logic of the probe. #define FIX_MOUNTED_PROBE #define NOZZLE_TO_PROBE_OFFSET { 37, 20, 0 } #define XY_PROBE_SPEED 1000
//#define MIN_SOFTWARE_ENDSTOPS #define AUTO_BED_LEVELING_LINEAR #define RESTORE_LEVELING_AFTER_G28 #define GRID_MAX_POINTS_X 5 #define E0_STEP_PIN 42 #define E0_DIR_PIN 40 #define E0_ENABLE_PIN 63
You shouldn’t move into the negative, right? The negative is on the other side of your endstops.
The part of the software that limits this is the soft stops. There is a gcode to disable them, but for some reason, I can never remember which one it is. M121, or M211 or something with 2 and 1.
with negative i only ment the direction, not a negative range the x-axis. so when the probe is bed leveling it is moving like show in the following table
Position | X on LCD | real X | Y
34 34 34
68 68 34
102 102 34
102 102 68
68 100+-4 68
34 98+-4 68
34 98+-4 68
68 131+-4 102 // here it moves out of the defined build plate
102 164+-4 102
i assume it has something to do with my stepper driver or with the pins that control the driver. because i was able to create a work around by wiring the X2 stepper in parallel to X1 stepper then everything was working as expected
i dont think that it is the dir input, because:
1.) when i am not ABL-mode it moves without any problems to negative direction.
2.) i ordered a new arduino, a new ramps1.4 and new stepper drivers. And i am still having that problem
it is definitely the something around x2-stepper controller. when i am wiring the stepper in parallel at x1, everything is fine. when I wiring them at X2 then the x-axis moves only in positiv direction (only while ABL!!)
is it possible that it’s some how a timing problem? i ask that because i use a 6th stepper extruder. before i attached it everything was working fine… ?!?
You appear to be using pin 42 twice - is that intentional? Maybe you need to move the lines where you define the E1_CS_PIN up higher, before the check to see whether it is defined…
