well i guessed this would happen… so far i have followed the instructions through to installing visual studio… installed platformio… can get it to load… i have downloaded rambo v1.4 dual end stops and un zipped it… it will open up in folder but i cannot get the tick down the bottom … stuck…
You have to open the project from the platform io open dialog.
Are you using the firmware from MarlinBuilder releases?
Ok now I’m getting somewhere… Will try after work
All good thanks… i got the firmware loaded and connected to my motors… everything appears to be working manually… thanks again
