Hello,
planning a 60 x 40 x 10 cm MPCNC right now. Will be used for milling aluminium mostly. What conduit (25 mm) wall thickness should be used here best?
I was thinking of 2 mm pipes, but I read somewhere on the forums this could be too much weight. On the other hand, 1.2 mm is cheaper too, so there’s two advantages of 1.2 mm wall thickness over 2 mm. Does the finishing (polished or not) matter?
1.) sanded finish steel, 25 x 2 mm (most expensive) http://www.metall-kunststoffhandel.de/produkt/edelstahl-rundrohr-025x20-mm-geschliffen-k320/
2.) chrome finish steel, 25 x 1.2 mm (moderate priced) https://www.heimwerkertools.com/schrankaustattung/schrankrohre-schrankrohrlager/schrankrohr-rund/haefele-schrankrohr-stahl-schwarz-gebuerstet-eckig
3.) non-smoothed steel (rough outside), 25 x 2 mm (cheap) http://www.ebay.de/itm/Stahlrohr-Konstruktionsrohr-Rundrohr-Stahl-Rohr-von-10-0-bis-139-7mm-/272262888875
edit: found a long thread on these forums, I tend to 2.) because it’s lighter and easier to cut by myself.
