This is my 2nd table build as I was having issues keeping things square. So I built this 2nd table and its hard to come by square lumber. As you can see below, or maybe not, its hard to pick up on camera, my left rail twists and bows slightly inward pushing the right y-axis plate off the rails. Ive considered welding together some steel rails with square steel cross beams instead of the wood. I designed this 2nd table so the rails and cross beams holding them can be removed. The table itself was built rather well. Any other suggestions?
Concept I had in mind for changing to 1-1/4" steel square tubing, but I will have some space on all sides if I change to the square tubing. (steel seems to be cheaper than aluminum at the moment around here by about HALF!) I blame the beer canning facilities, but not the beer. Yay beer!
Edit: However, my stop blocks/belt holders may be a bit too big for 1-1/4in square tubing.
