I’d suggest a 16A device is more than sufficient for these small routers for example this:
https://www.digikey.ca/en/products/detail/littelfuse-inc/BTA16-800CW3G/1961059
ok its worth a shot and a few bucks cheaper i will order those now thanks alot
Just be aware that the package is slightly different. The pinout is the same but you’ll need to splay the legs a touch because it’s a bit narrower.
So I got the part and it unfortunately still doing the same thing . So as of now I’m just emailed them back and forth while they blame my wiring, sensor placement or router modification
