I successfully swapped my X and Y axis around. My X axis is now the axis on the rollers and the Y axis is now the tube gantry axis. Endstops work for both X and Y including dual endstops for X.
In the process I needed to move Z2 endstop from XMAX. I changed this in configuration_adv.h:
// For Z set the number of stepper drivers
#define NUM_Z_STEPPER_DRIVERS 2 // (1-4) Z options change based on how many
#if NUM_Z_STEPPER_DRIVERS > 1
#define Z_MULTI_ENDSTOPS
#if ENABLED(Z_MULTI_ENDSTOPS)
#define Z2_USE_ENDSTOP ZMAX <<< Changed this from XMX
#define Z2_ENDSTOP_ADJUSTMENT 0
#if NUM_Z_STEPPER_DRIVERS >= 3
#define Z3_USE_ENDSTOP YMAX
#define Z3_ENDSTOP_ADJUSTMENT 0
#endif
#if NUM_Z_STEPPER_DRIVERS >= 4
#define Z4_USE_ENDSTOP ZMAX
#define Z4_ENDSTOP_ADJUSTMENT 0
#endif
#endif
#endif
Triggering the Z endstops while sending M119 shows that both do trigger. It tells me Z Zmin triggered and Z2 Zmax triggered yet when trying to home the Z axis the motors to not stop moving when the endstops get triggered.
I noticed that when homing the X axis it show me X Xmin triggered X2 Xmin triggered which is odd to me
My endstops are plugged in as follows:
X to xmin x2 to xmax
Y to ymin
Z to zmin Z2 to zmax
I’m obviously missing something.
