The LR is kind of ālike thatā because we like to put the control LCD on the side of the gantryā¦
I still find it MUCH easier to adjust my mental picture of the machine to match the layout.
There are 2 components. One is to adjust the X and Y axes moving the drives so that the machine calls them differently. This is a firmware adjustment, and is not trivial, but also not terrible. Change the dual Y drive to a dual X drive isnāt too bad⦠Then the real problems beginā¦
The LR3 is designed to home at min X and min Y. If you swap axes, this will either become max X or max Y. You cannot simply leave the homing coordinates the same If you do, when you cut, you will end up with mirror imaged pieces. This is going to mean that after homing, you are going to want to make the machine do a long jog across the table to get to a reasonable home position to start your cut. It was pretty much at this point that I decided that it would be easier to just keep my mental image of the machine correct rather than try to adjust the machine.
I suppose that you could mirror image print the core, dust collection, XZ plates, and X belt tensioner, probably also the rail riders and bearing wheel pieces to change the X homing direction of the machine, then mount it facing the other way. This would allow you to home at the new X min and Y min. (You should not need to mirror print the Makita tool mounts, but I donāt know about other spindles if theyāre not symmetrical.)
I suppose that you could also probably just re-engineer the endstop switches to be at the back of the machine, instead of the front as they are, but that seems like a shame when thereās a very nice solution already there.
