jack
(Jack)
June 28, 2018, 7:55am
1
Hi, I am going for the leadscrew adjustment. Got my pre-flashed Ramps 1.4 in january 2017.
Downloaded the MPCNC813_GLCD_T8 -32nd stepping firmware but saw a line in the change log about a resistor. Do I have to do something with this?
Thanks,
Jack
If you have a resistor plugged into port T0, you no longer need it, if you don’t …perfect.
jack
(Jack)
June 28, 2018, 11:55am
3
Ah, yes, that’s what I already thought…
But, since I am an electronics-dummy I know I do have stupid questions: What’s port T0 and did you put a resistor in it when I purchased it from you, that I have to get out?
Thanks again.
vicious1
(Ryan)
June 28, 2018, 12:00pm
4
Second picture, to be clear there should be nothing there. Just like in the picture.
https://www.v1engineering.com/assembly/ramps-wiring/
jack
(Jack)
June 28, 2018, 11:47pm
5
Yes, I have a resistor to remove. Thanks
Cool, glad that made sense. It was actually a little harder to explain than I thought. Pictures!
jack
(Jack)
June 30, 2018, 9:46am
7
This leadscrew is an improvement indeed!
