So, I’ve been wondering… if I put a dremel on an mp3dp and flash the Cnc firmware to it, can I make it work as a tabletop pcb router?
I’d think that aside from maybe stiffness of the middle being a possible issue with a big dremel instead of a small extruder it should work, right?
Maybe then design a new center part that doesn’t snap together and mount the dremel there…
Thoughts?
