Hello,
Attempt of MPCNC from Spain here! Thanks Vicious! I hope you all understand my poor english.
I’m having problems with movement, especially in Z axis, and I read plenty of times at the forum to loosen o tighten the tension bolts. It is not clear to me if the tension bolts should have play in the holes when they are loose, in the parts that I printed they are tight although I have them loose to the max. I can’t move them by hand.
I suspect my printer do holes smaller than they should and maybe I can’t do a succesful MPCNC.
