I’ve used my mpcnc to cut large things (on the scale of inches), but it seems to be not so good at small things. I mainly see the problem with small text. I’m attaching a jpg of a test pattern which has shapes and text. The shapes look pretty good - parallel sides, correct size. The text seems a bit squiggly. I went back and adjusted the gantry as described in the assembly documentation - make sure all bearings are touching, etc.
Please look at the output and tell me if you think this is as good as I can hope for, or is something clearly amiss?
I’ll attach the e10 file too if possible.
Thanks.
