Text is being carved backwards
Hi all,
I’ve been trying to do some carving using a V-bit and wanted to carve a name in a frame but I was quite surprised when it carved backwards, for example “word” was carved as “drow”. I assumed it was my unfamiliarity with Fusion 360 so I sought help on their forums and after a review it seems the gcode is being produced correctly and they have suggested it is a machine set-up issue. The Fusion 360 simulator always showed it was carving correctly. Thus my post here to ask for help in understanding where should I start to resolve this on my LowRider2.
I am using a Rambo v1.4 as provided by Ryan and I have not made any modifications.
For Fusion 360 I am using this post processor: DIYCNC Milling/Laser - Marlin 2.0 /DIYCNC_Marlin20 which has been working well for my normal panel cuts.
I wonder if the issue is my preferred orientation where X is the length of the bed, and Y is the height of the bed (that moves the carriage side to side on the bed).
Anyways, I hope there are some steps I can go through to check/test?
Thanks for your time to review and reply.
The +Y direction should be counter-clockwise 90 degrees from the +X direction, or your parts will come out flipped one way or another. I’m guessing your +Y direction is clockwise from +X?
Hi Jamie,
Thanks for your reply.
Can you clarify further or ELI-5 it for me? Picture/sketch would help and I’ve attached what my table is.
Is it a matter of reversing plugs on the Rambo then?
You should reverse the direction of X. 0 on the left will solve it.
Thanks guys, I know that seemed simple but for me it was hard to tell if software or hardware. That did indeed fix it. (reversing x plug).
Now maybe Fusion360 orientation and my orientation will be the same, lol.
