I feel real dumb for asking this, but can’t for the life of me figure it out. Can’t find any posts with a similar issue, either.
It’s simple, in concept. When I would list my files on the TFT SD Card in the CUT menu, they used to be sorted by date… i.e. the last thing I put on the card was the 1st thing listed. Something happened, and now it’s in some weird order; not even alphabetic! Reset didn’t work. Reloaded the config.ini didn’t work. Now what?
Top pic shows my hardware, which I’m assuming you recognize!
The next two show my CUT menu, selecting the TFT SD, and then the list. It’s this list that USED to be sorted with my latest projects on top. Now, somehow, the are in seemingly random order.
Hey Jeffeb3. Thanks for joining! So… I did look through the whole config.ini file, and although there are a few items about listing, there’s not one about sort order. It’s entirely possible that I simply don’t have it in this config.ini… Maybe someone knows the right variable to use?
Here’s the few “list” things I do have in config.ini (I hand selected these - this isn’t ALL I have in here):
#List View Border Color
list_border_color:15
#List View button background color
list_button_bg_color:15
#### File List Mode
# show file as list
# Options: [enable: 1, disable: 0]
files_list_mode:1
#### Long File Names Support
# On Marlin Firmware, The TFT will autodetect Long File Name supported
# Auto-detect is not available for other firmwares like Smoothieware
#Options: [enable: 1, disable: 0, auto-detect: 2]
long_filename_support:1
And other stuff that might be important:
#### Default Mode
# Options: [0:Touch Mode, 1: Marlin Mode]
default_mode:0
#### Onboard / Printer SD Card Support
# On Marlin Firmware, The TFT will auto detect Onboard SD Card
onboard_sd_support:2
HA! I built this thing a year ago! I’ve forgotten everything and if I need to do any firmware stuff, I’ll have to relearn it all. It’s been working great for me, so up until now, haven’t needed to dig into the code! Was really hoping for a simple solution to the seemingly simple issue.
I would be careful though. The new firmware isn’t backwards compatible. Once you go to the new stuff, it may not let you go back. We have seen some weird flipped icons when going from the latest to older firmware.
NICE. Well… I wouldn’t be going backwards, right? (and for S&Gs, I tried that variable and didn’t work. Duh!)
it’s BTT TFT35 Version 2.0
Firmware: TFT35_V2.0.26.x
What is the latest I can use with this hardware?
i guess I’m going to have to relearn this stuff. I do have my original BIQU_TFT35_APP1_V2.0.26.x file. I’m going to re-install it.
