I have a skr 1.4 turbo and tft35 e3 connected to my lowrider2 dual endstop.
my problem is that the screen does not respond correctly to M0 / M1 commands.
- the text i coded that should be in the pop-up does not appear
2 when I press ok the code does not continue. it works well enough in merlin mode just not in touch mode.
I am using the official firmware for TFT35 E3 as the firmware from this page presents several issues in the form of unknown errors and M82 errors when I turn on the cnc. to that there was no cnc menu which i thought there would be.
The latter is ok as I have coded some custom commands in config.ini to use for zero workspace, z-probe etc. but thats where my problem comes in with M0 / M1 as they are used for the z-probe.
I have made changes in marlin firmware by activating EMERGENCY_PARSER among other things recommended for the TFT35 E3
