I am messing around with the tft35 and the list of things it is doing at startup is worrisome. Any idea if it can be stopped.
I am pretty sure I have all the boot gcode disabled in the config file. If you use the standard theme you can see a list if things it runs ending with a “Z2.0”, unified theme you can here it and only see the “echo Z2.00”
I really do not want this screen moving the Z axis on boot. Any ideas?
I used the firmware from this thread MPCNC BTT TouchScreenFirmware for TFT35 2.0. I have a couple of errors with unrecognized M or G code but i think it’s due to board firmware settings.
I have not been compiling it I just used the bin, config.ini, and tft folders. Unified version as the regular seems to be missing images for some reason.
Power loss is all set to 0.
if you try the parameter menu is seems to do the same thing, so maybe that is reading in the firmware settings? I have not flashed new firmware yet, maybe I should start there.I will look into your links David and Mark, thanks!
Dang, Mark, you saved me a ton of time messing with the menus! I had seen that thread but without digging around I didn’t realize how much work was done! NICE!
I haven’t used it much yet, but it is working well. The menus are nice and easy to get around. I’m still getting used to the whole process before i dig in and fix the errors i get. I’m running from the sd card mostly and using the tft a lot with no performance issues. Now if i can just get repeter to relably connect i’ll be set
When i power on I get no printer attached. Then that goes away on its own and unknown command “m420 s1” ok. There waa one other error, but it hasn’t came back up. It might berelated to something i did.
Hi!
I don’t know, if someone managed to stop this behaviour, I haven’t.
Therefore I created an issue on github github / bigtreetech/BIGTREETECH-TouchScreenFirmware/issues/807
