Check out the garage organizer/MPCNC. I just put it together. There is still a lot of testing to do. I used aluminum foil emergency blankets around the inside to try to keep some heat in. My garage isn’t heated and it’s pretty cold. There’s acrylic on the front. It’s not a great insulator but at least it keeps the cold air out.
The legs aren’t screwed down yet, but they’re pretty wobbly. The thing shakes around a lot. I’ll probably change to having the corner blocks mounted to the sides which are 3/4 inch particle board.
When I start a print, it starts printing immediately and doesn’t wait for the extruded to heat up. How do I fix this? I’ve tried both ramps firmware versions.
That is a default setting for all printers. Somehow that got changed. Try resetting the defaults or reinstalling. I like cura just not the standalone. I like repetier, simplify, matter control, check out Prusa’s slicer as well.
I have the recommended setting on the extruder page.
