For a 3" Z height, but these size legs don’t reach the full length between the two leg pieces. Should I recut my legs for 3.25" Z (the default z in the calculator) so my legs will the 2.5 and fill the height of both leg pieces? Would it be problematic if the legs pieces are resting strait on eachother instead of on the weight on the legs (typing this out makes me sure this is bad)?
I believe the minimum Z height is listed as 81mm which is 3.189". You’re right. That the scenario you mention wouldn’t be good. If you’re using imperial then 3.25" is what should be used and yes, I think you need to recut the legs.
