Upon starting this project I set out to build a machine big enough to build tall dice Towers small furniture and large objects with walls only I have done it. it prints okay quality not pristine trying to post any helpful hints I found for making an oversized build to get that build area you’re trying to make stable
Trick number one attach top and bottom of frame to solid structure at as many points as possible IE house or garage you’re actually in built onto the actual garage or house
Tiptoe cross frame tension wires with turnbuckles remember once you get them on one way you have to have the other essentially making an x on a side of frame that you can secure to a solid object zip tie wires together and if at all possible put some type of dampener so they don’t act like Springs and cause you’re built to sway
Speed is not your friend when trying to produce a large build plan on going very very slow like 30% or lower
Tiptree upon deciding to build a large printer remember it has to have as much space above as below the top of the printer if your z-axis touches anything it will throw off your print
