Is there a trick to tightening the bolts on parts like the feet? The plastic surrounding the nut makes it so a crescent wrench can’t hold on to it.
If your finger isn’t enough try some needle nose pliers, or jam a little flat head screwdriver on a flat. It does not need to be tight.
