I have the SKR 1.2 from V1 , and my Tiny Touch Plate is arriving today, is there anything I need to do to the firmware to be able to use this? Also, is there any documentation on where/how to wire it up on the SKR 1.2?
Use the Z_MIN connector on the SKR. Plug the black wire to the (-) terminal on the SKR, and the red wire to the (S). Attach the black wire to the clip, and the red wire to the touch plate. If you’re using the V1 firmware, or the LR_Dual firmware, it should already be set up.
Thanks, I will do this once it arrives!
Yes there is! It’s a bit difficult to find the info you are after but here’s a direct link:
https://docs.v1engineering.com/electronics/dual-lr/
Have a look at this page about half way down.
