Tool Holder Tightening Fixture (3/4" Alu on the MPCNC!)
The MPCNC has been a great introduction to CNC routers and a fantastic hobby for over a year now . I’ll soon be taking the leap to a significantly larger machine that uses ISO30 tool holders! I decided to make my own tightening fixture for the new tool holders instead of purchasing one. I already had some 3/4" 6061 Aluminum in the scrap bin that was well suited for the job.
My build: 29x29 burly bruh from NC
What we’re making.
2020-04-26 19_46_14-Fusion360
3/4" aluminum cut to rough size and marked for pre-drill.
IMG_20200425_140503
Pre-drilled a 1/2" hole to avoid needing to plunge endmills.
IMG_20200425_141804
Drilled a few more holes and screwed the work piece down onto the table.
IMG_20200425_160535
Lots of adaptive clearing paths to match the profile of my tool holders.
1/8" single flute endmill with 17mm LOC
2d adaptive toolpaths
27000rpm, 2mm doc, 10% woc, 0.001" ipt
I ran a lot of separate programs while creating this part. The part hole was off by about .2mm but I was able to compensate in CAM and re-profile the pockets until I had the fit that I wanted. I was pleasantly surprised that the combination of dual end stops and g38 routines were repeatable enough to give the accuracy I needed. No visible steps when repeating a program, etc.
The air blast lower mount worked well enough to keep chips from piling up in the pocket.
IMG_20200425_192912
The rest of the part required an end mill long enough to reach down through the 3/4" stock. I could have flipped the part and used the same 1/8" tool that I used the first go around but I didn’t want to have to re-indicate things. Picture shows test cuts with a 1/4" single flute cutter that could do a 1" DOC. This is the first time I’ve used a 1/4" tool on the MPCNC for anything other than chamfers. I probably wouldn’t try running plunge or slotting toolpaths with them but it seemed to work well enough for the 2d adaptive paths required here.
single flute kyocera 1/4" carbide endmill, 25000rpm, 2mm doc, 5% woc, 0.001 ipt
IMG_20200426_111709
Yea can hear a the slightest bit of chatter between 9 and 6 o-clock. Never could figure out why.
Lots of tool stick out…
IMG_20200426_113818
Ran a few quick chamfers to break the sharp edges and it’s dood enough to start using it. I’ll clean it up on the new machine when it’s complete.
IMG_20200426_141448
Using the fixture to load a tool:
Cool project! What new machine will the ISO30 holders go into?
Going into more/less the same build from this video: Avid CNC Benchtop Pro - Aluminum chatter analysis - YouTube
Exciting stuff :slight_smile:
That is really exciting! That machine can really move som Aluminium :open_mouth: If you don’t mind me asking, what will something like that set you back?
Good luck with the build!
Do you mind sharing this file?
