Which one are you using and why?
Tool Mount (Allted) or Universal Mount 525 (HicWic)?
Are there others?
Are there others?
Depends. What are you mounting? Ryan’s is stiffer. heh. The universal mounts work if you’re bouncing between 3d printing, lasering, and paper cutting, but it’s too floppy with a router.
Sorry, which one is Ryan’s? I would like to attach the laser, I built with the same parts as the PDF
Ryan = Allted, Vicious.
I use Allted’s because that’s the one I use.
I looked at the others, but I won’t be switching tools very often. DIdn’t make sense trying them.
I may have to design a part to use with my laser, figure that would be cheaper than buying an entirely new laser system.
