Hi again, a few weeks ago I also questioned about this problem. Then I decided to buy everything from your website. So I did. Yesterday I installed everything and it’s working better then before. However: the biggest problem is still there.
- Did you buy everything from here? a) Yes, except the 3d printed parts
- Are you using end stops? No, running on PC
Video of the problem: https://youtu.be/J3XvWBnhKOs
At 0:56 seconds you can see the problem really start.
I first made vicious logo with from the sample file with the pen. This went well, except for the end. But that could also be because i don’t use a pen mount. Then I began 3D printing with the basic settings and the test file from: https://www.v1engineering.com/import-extruder/. Repetier host settings are also taken. I can’t find the problem anymore and running out of ideas how to fix this. I hope with all this information I can finally find the solution. The hardware isn’t the problem anymore and the software has the correct settings. As I measure the distance of all parts are correct. Hope you can help me.
Thanks in advance, from a (now) clueless 3d printer maker.
