Okay so I have my table mostly setup, but I’m just struggling a bit with the correct motor polarity and wanted to check on a few things to make sure I’m not crazy.
When I power on the RAMPS board and use the “Motion” section on the LCD to move, things work as expected (positive x goes to the right, away from the endstops, and positive y goes further back away from the motors).
However, when I use the “Home” function on the LCD, it does not move Y first, it crashes and keeps trying to run indefinitely in both -X and -Y. The switches do register as triggered when depressed using M119 gcode.
Also, I’m not sure if sandify is supposed to auto-home first, but every sandify gcode I’ve tried to load, and the device takes off in the +X and +Y direction indefinitely and crashes into the maximum extents. Does sandify try to home first? If so, why does homing with gcode go the opposite direction of homing from the LCD?
Do I have something flipped around on one of my motors?
