hi I got the 1.4 dual firmware. Looking at the guide I wired it up. No led d light. Lit up when I plugged it in I measure 12.4 v. Across the. Power screws. Lock down and test the fuse. Looks good. No resistance. Did I miss something here
Don’t forget the jumper
and watch that polarity stays consistent all the way from the power brick to the connections at the board.
Yeah I figured it out on the wiki for Rambo. I took care of it it’s working. Now except my z axis will run. But when the coupling is hooked up it clicking. And not moving the z axis up or down little stuck there
That means it is too snug or needs lube. Try making sure the brass nut is a little loose.
Thanks. What it was was I tighten the brass but down to tight. There was some misalignment there
