If you are cutting your own tubing, I found this free website that you can use to maximize your tubing lengths before buying. You will enter the stock length, cut kerf width, and then the various lengths of the axis and legs. Click solve and it will spit out a diagram showing how many stock lengths you will need and which lengths to cut from each. It will also let you print the list or download as a PDF.
optiCutter.com
Hey Travis, that is a good find but the link is not working. You switch the URL and the title
Here is the working link.
Opticutter.com
Thank you for the find!!
Oops. You are correct. I fixed the OP.
Thanks!
