Hello, showing CONNECTING in the DRO, and [MSG:Reset to continue] on the Console, but all commands are grayed out.
Only alternative is connect/disconnect button but again same messsages.
Any help is more than welcome.
Using GRBL1.1
UGS 2.0.12
UNO original
Arduino Shield V3
Do you have the correct baud rate and serial port selected? If I remember correctly, I had to change it from the default when I was trying a similar setup.
To diagnose if this is UGS vs something else, you can try using a basic terminal program to read boot up messages if any, and send a reset to see how it responds. If that seems to work well, then it’s definitely a problem with ug
Yes I did, install GBRL and UGS again, it works if I don’t tick the end stops and homing. But when homing only home X and Y, axis Z does not move. Thanks for the reply
I have never used homing. So i will not be able to help much i use hard stops and a touch plate. I use the hard stops to square the x y. Then use aluminum tape and the probe module and set the x and y edge then probe the z hight for each tool change
UGS greys out the command line (and other functions) until it can communicate with a valid GRBL. When you connect to the board do you see the list of current settings in the console window or just a
That print out is not from a ‘live’ uno board - just an uno I flashed to get the screenshot.
Soft limits requires homing to be enabled but not the other way around. see GRBL github for more info.
Those settings would allow homing (at the start of a job for example) but if you commanded the carriages either over or under the physical limits it would try to get there. The problem with hard limits is once the switch is activated you have to physically move the carriage off the limit switch and soft limits are not needed unless you screwup the size of the job or forget to enter your home position (something you cant do if you ‘home’ the m/c first). I think you will pretty soon find limit switching to be a PITA. It is not like the average laser m/c will self destruct if a carriage hits a hard stop.
I also struggled with this once in a while, I now realize that it only happens when I connect the arduino to wrong usb. Now i marked the one i should use, just so i dont jave to memorize which is what, all i need to remember is where port 6 is
I would try another the other ports, or maybe go through the set up of us again and remember what port you used while doing this. That’s what I did in the end
Ugs does not use exactly the same commands. I get an error like $ not recognized. You have to go into firmware via wifi to configure motor configuration changes. Then you just connect. Things should work. I haven’t configured mine yet, because I need to figure it out the mm per cycle. Startout doing the travel for mm distance before you doing any other changes, because if you change the number of cycles will change the distance movement figures.
