Understanding Rapids...
Ok folks. Right when I when I thought I was getting the handle on this, Ive run into a Z-Axis issue. I know the lost Z-Steps have been beat to death here. Ive previously been using Estlcam v10.xx and RC7, had the rapids set according to what was recommended and have not had one single issue.
Ive since been trying the Aspire software and yesterday carved a 2hr job with one little Z-Step mishap. I assumed it was a fluke and set out today for the real run. About 40 mins in I ruined a piece of oak as the Z-Steps went nuts. I tried again with similar results.
I thought that the RC7 firmware would limit the rapids to keep this from happening?? Any advice would be appreciated. I’m not sure how to “insert” g-code as Ive seen others mention to alter the g-code (speeds).
Ive been using the ““Emco VMC 100 ATC (mm)(*.nc)”” post processor as I read on here somewhere thats what someone was using.
Thanks in advance for the help as I cant keep wasting material.
The software updates article has all this info, on the homepage. Im not at a computer right now.
I found a post processor that someone created for Vectric that I am currently trying. Maybe that will cure it? Fingers crossed
Just a quick update. The post processor I downloaded for aspire seemed to fix the z step issue. But…it appeared again this evening. It’s real sporadic. No pattern to it. ran a 2hr job yesterday without issue. I may try double checking the stepper voltage for the Z but it was all bought here and should be good. I’ll update if I do next anything out.
P.S. The Aspire software is awesome. Should be though. 2k for the full version
Double and triple check to make it’s not trying to move Z anywhere faster than the firmware supports. Most post processors will try to move Z at the same speed as X and Y somewhere. When you send too fast of a move to Z weird things can happen. My personal thoughts are that it does a signed number overflow, changing positive numbers into negative…
Bill, I’ll be honest. I’m not sure where or how to look. Here is the post processor I’m using if you know what to look at. https://www.dropbox.com/s/2zchoy8q9g30yjs/Marlin_mmSafe_Z.pp?dl=0
Here is my Post Processor Info If anyone can help me
  • Emco VMC 100 Vectric output configuration file
  • History
  • Who When What
  • Mark 02/01/2009 Written
POST_NAME = “Emco VMC 100 ATC (mm)(*.nc)”
FILE_EXTENSION = “nc”
UNITS = “MM”
  • Line terminating characters
LINE_ENDING = “[13][10]”
  • Block numbering
LINE_NUMBER_START = 0
LINE_NUMBER_INCREMENT = 10
LINE_NUMBER_MAXIMUM = 999980
  • Formating for variables
VAR LINE_NUMBER = [N|A|N|1.0]
VAR SPINDLE_SPEED = [S|A|S|1.0]
VAR FEED_RATE = [F|C|F|1.1]
VAR X_POSITION = [X|C|X|1.3]
VAR Y_POSITION = [Y|C|Y|1.3]
VAR Z_POSITION = [Z|C|Z|1.3]
VAR ARC_CENTRE_I_INC_POSITION = [I|A|I|1.3]
VAR ARC_CENTRE_J_INC_POSITION = [J|A|J|1.3]
VAR X_HOME_POSITION = [XH|A|X|1.3]
VAR Y_HOME_POSITION = [YH|A|Y|1.3]
VAR Z_HOME_POSITION = [ZH|A|Z|1.3]
VAR SAFE_Z_HEIGHT = [SAFEZ|A|Z|1.3]
  • Block definitions for toolpath output
  • Commands output at the start of the file
begin HEADER
“%0004”
“[N] G54 T0[T]0[T] G00 [S] [XH] [YH] [ZH] M03”
  • Commands output for rapid moves
begin RAPID_MOVE
“[N] G00 [X] [Y] [Z]”
  • Commands output for the first feed rate move
begin FIRST_FEED_MOVE
“[N] G01 [X] [Y] [Z] [F]”
  • Commands output for feed rate moves
begin FEED_MOVE
“[N] G01 [X] [Y] [Z]”
  • Commands output at toolchange
begin TOOLCHANGE
“[N] G00 Z40.000 X0.000 Y10.000 M00”
“[N] T0[T]0[T] G00 [ZH] [XH] [YH] M00”
  • Commands output for a new segment - toolpath
  • with same toolnumber but maybe different feedrates
begin NEW_SEGMENT
“[N] G00 [SAFEZ]”
“[N] [S] M03”
  • Commands output at the end of the file
begin FOOTER
“[N] G00 Z40.000 X0.000 Y10.000”
“[N] G53 T0000 M30”
Thanks for any help
Doesn’t look like that changes the RAPID_MOVE speeds from what is in your firmware, but it does use RAPID_MOVE. How do you have the firmware configured? If Z is set to defaults in a lot of cases that’s the same as X and Y and that would be assured to break randomly.
The firmware is RC7 taken from here. Could I add to this a couple lines to limit it? Or break up the XY from the Z speeds.
I’ve watched a few YouTube videos, enough to know what I think I need. But not sure how to implement it for me.
hello group,
I have installed ESTLCAM V9.016 but a little different from the previous version.
I don’t know what I do for RAPID FEED. the new version does not (RAPID FEED Z).
can you help me?
thanks
You need the latest version. Download that (v10) and it will be there.
Well, 600mm/min is 10mm/sec and IIRC the maximum speed for Z needs to be around 8mm/sec. Try setting the move speed for Z to the 480 shown for rapid.
That’s just it. I’m not sure where you are seeing the speeds. “480 shown for rapids”. I’ll edit this file, if I know what to edit. I’m clueless with this processor stuff.
That was another fella asking about Estlcam. I may have it. I found a youtube video that helped. I added
“F[FC] XY”
“F[FP] Z”
To the post processor and it appears to have separated the rapids for the X&Y and Z However I do still see one entry for Z at 1200.00 (haulin azz) so we’ll see.
https://www.v1engineering.com/software-updates/
https://www.v1engineering.com/estlcam-basics/
Ryan, this is NOT for Estlcam! I am trying to fix rapids for Vectric Aspire.
And scratch the previous post about may have it working. I still see [F] 1200.0 in the gcode. I dont know what I’m looking at but I’ve learned enough to know thats not right
My bad.
It’s all good, I’m just getting flustered since I have no clue WTH I’l doing lol
