UGS is for grbl. RH is for Marlin. You just have to squint and ignore all the words like “print” and “heat” and just imagine it says “cut”.
The touch plate works regardless of the sender software. It will be wired into the zmin port (s and -, don’t use +) and G28 Z will send Z down until it touches. You can test with M119 before trying the G28.
Take a look at the software workflow. It doesn’t have to be repetier host, but I am mostly sure UGS won’t work with Marlin. Cncjs, pronterface, pronsole, these all work.
Can you put GRBL on to the RAMBO board? I’m curious as UGS looks much better than RH to me. Things like overrides, reset zero and the DRO make it easy for newbs like me. I’m not saying RH doesn’t do those things it’s just how simple UGS makes it.
Hi Jeff I did check it out and it looks great. I cannot figure out why the “work position” doesn’t update though. I see there is a long thread on WCS from 2019 and early 2020. I am not sure if that’s what I’m experiencing or not. If it is it seems like another knock on Marlin… Let me know if I’m missing something and that the work position should update as that’s going to keep me from using it. I like the tool otherwise, it will be a big help especially with your pi image!
