Hello All
Last nigh I though I would be smart and use ESTLCAM to run my MPCNC.
Fail!!!
And to make it worce, (As a Warning to others that may wan to tey it) It reflashed my RAMBO, So I have needed to spend the morning learning how to reflash. (Think its done now but need to reconnect to the machine)
So has anybody else made this work? is it better than repetier-Host?
I have been, but didnt like swaping from one to the other, and EstlCAM says it can do it, So why not try
In the learning phase I like t try different things. I do however appreciate you have already done this on our behalf, and I thank you for that, But I like to tinker…
Did you get it to reflash? I did the same as you and now I can’t get it back to working even though I’ve reflashed with marlin software. Any help would be appreciated.
Never mind . Right after posting this I found that I was flashing the wrong firmware. I apologize for not investigating enough before posting.
