Is here a way to use matlab to control the MPCNC machine?
Im learning to code using matlab in my engineering class and would love to be able to test my code without having to to be in my schools lab.
Is it as simple as installing some drivers or is the firmware not comparable?
Thanks in advance guys!
vicious1
(Ryan)
2
Well I just responded to the other email.
You won’t use Matlab to control the machine you should use matlab to produce your gcode and then run the machine as is.
You can control it with matlab but that will probably come in a few more classes.
Ok thanks. I’ll do that. Appreciate the response
