i just got my MPCNC squared up again after cracking a core bracket because of a print defect I missed.
(new brackets on the core, slightly shorter arms for extra rigidity, and re-trammed it)
first thing after the test cuts was a new 5mm Al plate for my lowrider2 (i am slowly making all the parts to do a full Al upgrade on my lowrider2. (cnc’s to make cnc’s right?)
mostly because i wanted to run the X axis faster then is normally sane
the second motor / driver gives me extra torque
(i am also looking at putting a pair of nema23’s on the Y axis for the same reason)
i have a 5 driver board, my intention is to make a breakout for it, and power the 6th driver via a patch from the power supply, and split the step / dir / enable pins for the X axis drivers
thus making them “share” the X output signal (im using a GT2560)
If you were looking for more power, then I would just write them in series. There’s no reason for auto squaring. Series can affect torque at high speed, but it depends on your definition of high speed and a 24V psu would fix that too.
this is why my plan is to run 2 separate stepper drivers and slave them to the same set of control outputs from the micro controller.
i have done this trick before on my laser cutter and it seems to work fine.
gets me 1 driver per motor, but no auto squaring (which I don’t need in this case anyway)
