I’m using a v-bit to carve a circuit board. I’m using Estlcam and after I save the project I use ctrl-A to select all the cuts and enter .3mm for the Depth limit. I check several traces to make sure they are all .3mm. Then I save the cnc program and open Repetier-Host. When I look at my gcode all the depths for z are.05mm. I try running the program anyway and the v-bit barely touches the board in some places. I used the Tiny touch plate to set Z axis first. I don’t know whats going wrong. Do I need to enter .3mm in Maximum Carve Width?
Jerry
Clear Front Traces.gcode (768.4 KB)
