I am using the v1pi and i am having an issue with trying to zero out the z. when i click the icon to do it i get “echo:unknown command” “G10 L20 P1 Z0"” I’m not sure what to do to fix it and if i adjust the z manually then it just compensates for it. So I have to set z before I turn it on.
anyone have any ideas?It is sending the wrong command for Marlin. It should be G92 Z0. You can add a macro for that.
cool that worked. If i figure out how to fix it so it works i will post it.
