kcny
(kcny)
November 20, 2021, 11:03pm
21
OK great, I was about to reply that the gcode looks fine and was confused why it would shoot up to max height (then I saw your edit).
So if you want, you can now properly set your Z height and run the gcode and actually perform the cut.
My normal workflow is essentially what we just did:
Home all axes using the limit switches
Use cncjs to jog to my start position and do a G92 X0 Y0
Probe Z via a macro in cncjs
Run the gcode
MarkP
November 20, 2021, 11:05pm
22
So this is something i noticed. i normally use the zero out work offset button. i get an unknown command when that happens. is there something different with those buttons?
kcny
(kcny)
November 20, 2021, 11:18pm
23
I don’t believe it was ever implemented in Marlin, that’s why the commands are invalid:
Sounds to me like cnc.js is oblivious to the workspace changes. If it has a gui element to show workspace coordinates specifically, separate from machine coordinates, then you would think it would track the workspace changes. It seems like this is where the G10 L20 stuff comes in, and cnc.js is not catching G53 G54 G55 stuff.
I think I saw a Marlin update where someone had added support for G10 L20 as an alternative to G54 but I’m not sure if it got approved and merged into the official code an…
Henslee
(henslee hill)
November 21, 2021, 4:53pm
24
I’m using tests5 on my primo no issues yet
MarkP
November 22, 2021, 4:14am
25
Thanks for all the help guys. did a few more sample cuts with vcarve before i deicde to make the purchase.
