Hi1
I’ve just started printing parts for the MPCNC. Finally!
I’m printing “RollerMounts” at the moment.
When printing part has two 3mm vertical holes (I think 3mm)
From some reason, those holes end up oval!
So, I’ve printed 30x30x30mm test cube with two vertical holes in it, 6mm and 4mm
Pics attached
On first picture you can see how is cube oriented when printed.
On other pictures you can actually see how oval holes are
All other parameters of the test cube are fine
I would really appreciate if anyone could help me solve this.
I presume that small size errors of 0.2mm width/length/height won’t affect anything in the assembly proces but I would like to eliminate oval holes to eliminate any room for screws to play.
Or is apsolute print accuracy in every aspect essential?
Thank you!
Regards,
Walter
