when trying to build I get these errors and its from the github itself. tell me what info you need for me to explain the problems i am having. thanks here is a print screen of errors i am getting.
First, only the first error matters. The C++ compiler is kinda dumb and after it gets one error, it gets into lots of trouble.
Second the code doesn’t need to change. The .zip releases won’t be published if the compile fails. So the .zip releases in MarlinBuilder releases have been compiled.
Third, the instructions for setting up the tools are here: platformio.
