I wired up the motor and tweaked the driver last night, and using the lcd hookup checked to see if the extruder would run (it does!). Bought a bigger power supply and hooked that up. Is there any additional steps? do I need to change the firmware?
Steps and thermistor and you should be ready.
awesome, thats what I thought!
Hmm… tried hooking up the thermistor and its not reading it. Not sure what the problem is, I also tried to warm up the extruder and nothing. I must be missing something.
What thermistor value did you use in the firmware?
