A lot of troubleshooting questions from me now, but I am also doing a lot of cutting and I am still a newbie
After 1h my job ended unexpectedly… The machine started going sideways and broke the bit and then went a bit further away and just stood and went back and forth 2-3cm like if it didn’t know what to do.
So I shut everything down and was happy anyways because the job was still salvageable…
But then I notice that my Y motor is a bit wonky now. What could have happened to it… Is it broken? The motor shaft does not slip on the screw. It runs smoothly when pushed manually without steppers on, but sounds terrible with steppers on.
You can check continuity at the board end. On the motor connector there should be continuity between 1-2 and 3-4 (And NO continuity 1-3, 1-4, 2-3, 2-4.)
Chances are that the connector for the wiring extension harness got pulled apart, or else the wire socket at the control board came unplugged slightly.
