I’m wanting to cut the entire piece of birch wood with a fully rounded edge and I was wondering which round over plunge bit I should get?
As in round the outside edge? That is best for a hand router.
Isn’t the DW660 a hand router or are you referring to a router table setup? This is the type I was talking about:
That is best to do by hand or on a table, with a router, not on a cnc.
ok thanks.
Yeah. You’re going to end up rounding over both your piece and any leftover stock. You’d end up probably having to cut pretty slow. I’d just get a normal round over bit and do it by hand after the piece is cut out.
