V1 Engineering Dual End Stop Kit. When I Auto Home from LCD screen, Y & X home fine to their end stops, but Z just keeps moving up and literally moves beyond the lower bearings. Seems to be expecting Z end stops?
How do I resolve this?
Is it just a matter of commenting out the Z portions here in the configuration.h?
// Specify here all the endstop connectors that are connected to any endstop or probe.
// Almost all printers will be using one per axis. Probes will use one or more of the
// extra connectors. Leave undefined any used for non-endstop and non-probe purposes. #define USE_XMIN_PLUG #define USE_YMIN_PLUG #define USE_ZMIN_PLUG #define USE_XMAX_PLUG #define USE_YMAX_PLUG #define USE_ZMAX_PLUG
There are two options for homing; in the “motion” menu and in the “custom commands” menu. The motion menu options homes x, y, and z; while the custom commands menu allows you to home x, y separate from z.
Now, to answer your question, I’m sure there’s a way to remove the auto home from the motion menu but I’m not the best person to walk you through the process. I know you can edit the custom commands in the configuration_adv.h file, just look for CUSTOM_USER_MENU but for the other menu items, someone else will have to chime in.
