Well I splurged, I am super stoked. I got it on sale as a display model. This is the ultimate MPCNC table, and my sexy new printer sitting right next to it at a maker faire gives me a reason to do one finally.
Need to get some different clamps but other than that, I will be flooding the internet with the ultimate sexy MPCNC pictures ASAP. Turn off the porn filter these are gunna be NSFW CNC pics. Red, black and Stainless…If I could only get black oxide stainless rails…
Whoa. That looks nice. I like the integrated power.
Did anyone else notice that the actor they used to illustrate the foot pedals has some dirty boots? You’re not fooling anyone Milwaukee. We know that guy didn’t earn that dirt.
You need to find a way to get some of that wood grain into your machines.
I think there are steel sealant things that blacken up steel. Diresta uses stuff like that all the time. They look kind of like marking fluid, but it ends up with a real finished look.
The “trial kit” is only $38! That stuff seems pretty cool. I am waiting for you to try it first. Then I suppose you’ll have to sell the hardware kits in black and gray as well.
Well, it smells like your big buddy after a week long chili eating contest.
I rubbed it for 10 minutes straight and had to keep applying the stuff. Looked midnight black with the gel on after 10 minutes. Rinse it off pretty grey but super promising.
[attachment file=50213]
Applied the “sealer” smells just like gasoline.
[attachment file=50214]
Touched it with a blade and it comes right off. Lighter that scratching a lottery ticket…
[attachment file=50215]
I don’t think it was worth it, I tried, hope I saved some of you the money. I am sure it would look cool but you would definitely have silver stripes after the first use. a quick rub with the steel wool and it is easily down to 50% grey. Seems to just put some sort of thin layer of oxide on it. Looks like the gel is a no go.
I bet it needs an anchor. Just like if you spray paint a smooth surface with an epoxy paint you can peel it off. If you rough up the surface of the metal first and degrease it the coating may adhere better.
Otherwise maybe you can parkarize or blue it like you do a firearm.
It is an etcher made for stainless. They have two others one requires muriatic acid dips, and the other requires heat. It might work, I am just not sure if I want to gamble with all that stainless.
If you want it scratch resistant it either needs to make it harder or penetrate. It makes sense that it bonded to the outermost stainless and that was easy enough to remove with a knife.
10 minutes of a serious reaction, I thought for sure I was ruining that piece by how it was looking. Then it all kind of oxidized off. I get that it is stainless but dam I had no idea stainless was, well, that stainless.
